Playing around with tuning my TRX 2.5 today. Finally getting it thru tanks without it stalling at all, turned out to be a leaking carb. Carb is replaced now, but I'm noticing that I dont have a lot of power (at all) when the engine is cold. Once it warms up, it screams, but before then its pretty boggy (running rich, doesn't even shift into 2nd for a while).
I dont know if this indicates a worn piston/sleeve, but it doesn't sound like it does (it doesn't stall at any time.........cold or warm), and the engine only has 1/2 gallon thru it.
Any ideas? I've tried going back to factory specs and then taking it from there, but I seem to be ending up in the same spot.
Thanks!!!
-Chris
Thanks!!!
-Chris
