This is what I thought originally... After messing with this thing for a few days trying to get the tune right (bad glow plug and all) I finally get it running top notch and ZZZZiiingggggggg the RPM's go up without speed. I thought at first it was the slipper clutch or engine clutch.. so I start checking into it and find the input shaft is turning, wheels are not. I never thought of checking the wheels or axles, I just assumed it was in the transmission. So today I pull the transmission, clean and inspect the oneway bearing on the output shaft gear, found a sheared pin for the 2speed clutch arm. I get everything back together and take it out for a spin... ZIiinnnnggggggg, it does it again... GRRRRRRRR I'm pissed at this point. WTH could it be now? I held the thing down to the ground and gave it all she had, axles are spinning like crazy, Left rear axle and Right front axle are spinning but the wheels aren't.
I'm off to the store to buy a new set of wheels/tires.
Question:
With a stock savage 21, would a set of Big Joes tires and Proline 40's be too much for this stock engine? Should I just stick with the stock size in a better rim?
I like the look of the Big Joes tires/proline combo and would rather go that route if its not going to kill the performance.
Question:
