Slipper clutch, what's wrong??
altern8
Hi, i just put reverse module in my savage25, it seems to be working just fine, there is just this one big problem, a truck dosent run at all, I mean the engine starts, throttle and everything works but the car is not moving forward nor backwards i can push a throttle all the way down but it still won't move... There is just a little bit of power going to the wheels cause if I lift it up the wheels will turn forward, in reverse, backwards, but it's just to slow to move the truck in any direction, what i noticed, and what i assume to be a problem is slipper clutch it seems very very loos, even if i tighten the nut all the way to the end it is still loose, you don't have to put any pressure to turn... and it wasn't like that before i took the car apart...
please, what do i do??? what did i do wrong, I am waiting for help,
thank you for all answers and advises...
bye, altern8
That or when you put the tranny back together you forgot to do something.
hm yeah... I spent last 6 hours taking the truck apart checking what;s going on putting it back together ...trying... and, hm, not a single clue.. i took the transmission box apart two times... and now i am so reaking pissed cause the problem was in wheels, yeah!!!! i don't know the name of these fellas s look here:
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXDHN1&P=0
left bottom corner. I forgot to put them into the holes before i screw the wheels on... thats why they didn/t turn... I'm so F stupid... :((
