First slash setup for stock racing. Track is tight with one long straight. Track is medium bite early on but becomes loose and dusty so I'd say medium to loose track surface.
Stock body trimmed slightly to avoid body contact but still looks stock, stock wheels and tires, stock motor and ESC. Stock gearing. Truck has very good rear grip. There is a mild push in corners that can be overcome with a blip of the throttle making this truck very easy to drive fast on medium surface tracks. Flies nice and level and only bottoms on the largest jump.
FRONT- Stock springs, 40WT oil, Shock in outer hole on Arm, 1/4 preload spacer, 2 degrees camber.
REAR - Stock springs, 30WT oil, Shock in Second hole from end of arm, no pre-load spacer, 2.5 degrees of camber, Stock tires flipped so the tread is backwards.
slash setup for mod racing. STILL IN PROGRESS Same track as listed above.
Stock body trimmed slightly to avoid body contact but still looks stock, Large hold cut in windshield to aid in cooling. Proline Bowties on stock front wheels at all 4 corners, VXL motor and ESC, ESC relocated to right side of chassis. Traxxas Alum Carriers and steering, 2S 5000 Zippy Lipo. All other parts stock.
FRONT- Stock springs, 50WT oil, Shock in outer hole on Arm, 1/4 preload spacer, 2 degrees camber.
REAR - Stock springs, 40WT oil, Shock in outer hole on arm, no pre-load spacer, 2.5 degrees of camber. Proline Bowties mounts on stock traxxas front wheels for slightly wider track.
This setup is still being refined. I've gotten the setup dialed in to the point where the truck is neutral in most corners and hooks up very well down the straights (wheelies sometimes) and jumps very well without bottoming out.
Currently looking for more traction in 180 degree and other slow corners as hooking up the power of the VXL when to truck is not perfectly flat is proving to be a challenge. Things I'm considering are a sway bar on the front, Lighter oil in the rear shocks or maybe swapping out the front prolines for stock tires for a little more push in the corner.
