I just started having some troubles with my Sirio .18, the problem I'm having is it is way bogged down when I hit the gas, and slowly creeps to speed, then shifts into second and handles ok. I have the HSN 6 1/2 - 7 turns out and low speed at 2 1/2. It was running ok, but I have recently added more aluminum and changed the clutch bell. I have just about every peice Hardcare Racing makes, the UE Suspension, & all Robinson Racing gears. I am also running the Sirio Big Bore pipe with a motor saver air filter, Robinson Racing 72t metal Spur & a 22t Clutch Bell, just running it with street tires on a flat surface, it hit 314 degrees after 3 or 4 passes on the street. I instantly killed it, popped the glow plug out and moved the piston all the way down to let it vent / cool, but I'm not sure why it's bogging down & over heating... any ideas?
Additional Info, if needed:
I have about 1 gallon of Trinity 20% Monter fuel through it.
I had no problems until I added the following:
Hardcore Racing Aluminum Chassis Braces
Hardcore Racing Aluminum Clutch Shoes
Hardcore Racing Titanium Pillow Balls
Hardcore Racing Knuckle Caps
Hardcore Racing Alluminum Receiver Case
Hardcore Racing Alluminum Servo Mount
Hardcore Racing Alluminum Tranny Case
Robinson Racing Steel Topshaft
Robinson Racing Vented Flywheel
MIP Center Drive Shafts
22t Clutch Bell
This may have added some additional weight, but nothing that I could imagine would cause it to bog down as much as it is... thanks again.
22t Clutch Bell
