Sirio .18-tx
Grekol
Can i put SIRIO .18-TX Pullstart ENGINE w/Rotary Carb, Threaded Crank into yokomo gt-4 rtr???
If i can't what is the best pull-start engine. PRICE DOES'NT MATTER!!!!
dude, anything is possible, it just depends on how much time you are willing to spend to figure it out, and money to throw at it :D I do know that the tx-18 will fit where just about any .15 did, maybe with some modification
Originally posted by Grekol
what kind of modification
The kind of modification that makes it fit. Start by placing the new motor where the old one used to be, line it up with the spur gear, drill and grind the chassis and motor mount till it works. Then comes the fun part of figureing out your linkage. ir you had a rotary carb before, it should be simple, but if it was slide carb, you might need to modify your linkage.
