So I took off my Ez start because it stopped working 3 weeks into owning my revo. So I put a pull start on which I was going to do anyways and took it out for a test run. Now my radio cuts out for 2-3 sec at random times. It can get in a straight line, turning, barley moving and then it comes back and is fine. i have checked the antenna, changed the RX battery and changed the remote batteries. What else should I check. When this happens the sensor light comes on in the truck. Nothing has been touched since the last time I ran it other than pulling the EZ start off, sealing the motor and putting a roll cage on. The roll cage is kinda close to the antenna but would that cause random signal loss?
