No, it is not. The usual culprit is poor gear mesh. Your engine mount screws (the ones that hold the engine mounts to the chassis plate--not the ones that hold the engine to the mount) are probably loose allowing the engine to pull away from the tranny. As you gun it and that mesh opens, the clutch bell tends to eat the teeth off of the spur.
My recommendation is to first get your mesh set properly and tighten the engine mount screws down (make sure you are using some blue loctite on those mount screws). Give it a run or two and see how that works.
As for the metal spur gears, I'll have to look them up. I'm pretty sure they exist, just have to find them.
If you need to know how to set the mesh properly, just ask.
