ohsnap
- Edge of the Piedmont
- Racing
Since a number of engines use a long glow plug (Traxxas for example) - what is the net effect of using a shorter glow plug in this type of engine and does it impact performance - and if so how/why?
How does it compare to changing the shim?
Installed - the shorter length glow plug won't reach the top of the compression dome - which to me means that it would be decreasing the compression ratio.
Does that recession (not reaching the top of the dome) impact fuel detonation since the fuel mixture has to be crammed up into that recessed area to reach the hot filament?
The difference between a long and a short plug is about 3/4+/- of a mm (.75mm).
Traxxas head shims come in three sizes .15mm, .25mm, and .35mm - so the net difference between the thickest and thinnest shim is .2mm.
I realize that the gap with the shim is spread out over the whole area of the cylinder versus being limited to the 1mm x .75mm hole in the top of the dome, but can anyone offer further information/perspective?
I've run a short plug in several engines (Traxxas and Picco for example) and while I haven't done a back to back (long to short) comparison I've been wondering about the net impact.
