shocks
nitroguy
hi just wondering if its normal for rear of tmaxx when you compress the shocks they dont come back up all the way maybe half way can you put in more spacers too make the springs stronger the front seems ok stays down a little not much. thanks.
Its normal for it not to rebound 100% when pushing it down in a stationary position. You can add spacers to tighten the spring rate also probably need to pull shocks off and re oil them as well. You want the rear just a tad stiffer than the front to make up for weight difference of engine in rear.
