Hi I'm a noobie to nitro still, I have a T-maxx 2.5 that was converted into a 3.3 it ran fine in the cool weather but when I took it out today there were two problems. First off I would run about 4 passes up and down the it would shut off. My idle is set high enough, when I went over to it it was steaming from the cooling head, I can't figure it out, it is set rich, I'm using a cool glow plug, and it's broken in. My second problem is it will rev up in first gear the try to go into second but stutter, I don't think the screw in the shifting box is the problem, I turned it all the way in then three turns out, it still did the same thing. Any help would be appreciated. Thanks
