several questions
i believe your charger is a bit advanced for me :p ill stick to old school ones...
one new prob guys :devious:
just yesterday i took apart my engine and cleaned the one way, cranckshaft and pull start with nitro spead clean and alcohol so it wouldnt slip, it was really dirty after some bashing i had done earlier. it was working fine but when i finished bashing today it made the same problem, it slips and doesn't turn the crankshaft every time i pull. but as the engine gets cooler it starts getting "traction" again. is this normal? if not, what can i do so that it stops?
my lhs at the US will give me the mx-3 75MHZ, 959 super brain, and the Reedy hump pack 1100MaH all for 200 buks. ill prolly get that or ill look around other shops. one question, to charge the reciever pack with the 959, do i need any cable, or i just connect the pack to the charger itsself?
BTW, the 959 seems a good bang for buck
or.. you could get a JR XR2 radio for 99 bux, and it will come with a good metal gear servo what works great for throttle.
JR radio and receiver, and servo 99.00 (cheaper on ebay)
RX pack, 20-30 bux www.teamhelotes.com (25 for a 2400mah pack)
charger from tower 60 piranha digital peak charger
grand total of less than 200.. and even less if you go on ebay..
charger is 49.99 at tower http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXCLD5&P=7
radio is 99 at horizon.. http://www.horizonhobby.com/Shop/ByCategory/Product/Default.aspx?ProdID=JRP234275
and 20 bux for a battery pack.. http://teamhelotes.com/~main/catalog/i71.html
grand total of 170 for everything
and on the 959 charger.. you will need to buy a female plug adapter to your battery pack..
