Setting T-Maxx Brakes
You should set the brakes however you like them.
As mentioned..... if you lock the brakes..... your gonna do flips and crash.
I have mine set rather light. However I will ocasionaly still ge a rollover if I hit em too hard.
you can put a small spring at the non-servo end if the break rod with a 3mm washer so the spring doesn't slip through the loop on the break arm. i found a spring at a auto parts house. brand name motormite p/n 40506 overall length 1-5/16, o.d. 5/32, coils per inch 13, wire dia .023. i found that cutting 7 to 8 coils off works good
