Set Up Hyper7
BUDDHA
RCTalk Qualifier
STATEN ISLAND
Need some help -
Have a ofna hyper 7 pcr pro.
powerplant- O.S 21v-spec b engine
Anybody have any set ups or where can i find some set upsfor this buggy?Any help will be appreciated !!!!!
thanx.
Buddha:
I'll check my build manual tonight and get back to you. Did yours not come with one?
u can check ofna.com. they have a forum and buch of people posted their set ups there.
but what exactly are u looking for?? diff oils used? springs? camber settings?? more info will lead to better responses
diff oils prob. 5,7, 1 shock oils 50 up front 40 in the rear. small sway bar up front big in rear. run arms level all the way around.
need anything else?
i never ran 1/8th scale buggy before,just 1/10th scale dirt and carpet racing.
Basically need to now everything -
diff oil,shock springs,shock pistons,shock oil,camber,toe,the basics
will be running up at barnstomers upstate ny,track is loose fluffy dirt.
ofans website has no set ups for the buggy just blank sheets.
any other websites were i can get any setup?
thanx for help
front diff oil 5000,center 7000,rear 1000,black springs,35 front shock oil 30 rear ,inside shock holes on arms,2nd hole bottom role inside rear shock tower,top inside on front shock tower,1 degree negative camber front,1.5 degree negative camber rear,20 degree front hub carriers.m2 compound crimefighters for tires.
The front diff 3000, center 5000, rear 1000. silver shock springs in the front, white in the rear. Get some ofna dominator shock, they have bigger shock shaft and are bullet proof. Come down one hole on the shock towers as they are a little shorter. 37 1/2 shock oil all the way around with Piggy Backs. 1 degree negative camber all the way around. Run the 22 degree hub carriers, this will require you to change the upper a-arms. If you can covert it to pbs(they have a kit for that) sure makes it turn on a dime. M2 crimefighters and make sure you balance the tires, it extends bearing life.
