On the Savage remote, the switch labeled ST is for the steering servo. The N refers to normal, and the R refers to reverse. If the servo is turning opposite under on setting simply switch it to the other side. You should be good to go. Your other option is to remove the servo and switch a couple of wires at the plug. Then you can leave the switch alone. What's the easier solution? Since you already have the servo mounted, throw the switch on the remote.
