I use Permatex Ultra Copper oxygen sensor safe sealant. You should be able to find it at WalMart or your local auto parts store. It works well and won't harm engine components. I have sealed a few engines with it and it works great. While you're at it, seal the backplate, carb throat, and HSN banjo fitting. That should give you a good full seal and eliminate those as possible air leaks.
