Arma
- Crawling
- Flying
“So Much Potential, So Many Issues”
On paper, SCX6 should’ve been a flagship RC crawler. But in reality, it feels like a rushed design that needs a lot of upgrades just to function as expected. After years on the market, it’s surprising to see that many of the known issues still haven’t been addressed and confirm what people think about Horizon Hobby and Axial (acquired for $19m in 2018).
What I experienced after just a few runs:
On the bright side:
This model can become something great—but be ready to invest and fix Axial mistakes to get there. Certainly not a beginner rig
- Transmission is extremely loud—a gear-crunching sound that feels abnormal for a rig at this price point. Many have reported the same. I have rebuilt the whole transmission - checked for tolerances, missing c-clips, revised bearings and carefully lubricated and reinstalled everything like a Swiss watchmaker. It has improved significantly - it even shifts flawlessly now. But a full teardown shouldn't be necessary - on the bright side, it forced me to understand how it works.
- Differentials need shimming right out of the box, or you risk stripping the gears ($50 per gear set).
- Driveshafts wobble noticeably. Ordered steel ones - also to improve the center of gravity.
- Front shock tower flexes when turning, which limits steering. It benefits greatly from an aluminum upgrade - get also a metal receiver box, not just shock towers.
- The panhard mount also flexes, which causes body roll during steering, especially on left turns. It's crazy to see the flex - it's like Axial's R&D have never built an RC car before. Stock front axle is a joke. Could have come with stronger panhard mount from the factory, it would probably cost $2 more to add the mount support. Unbelievably lazy R&D by Axial. Fixable by upgraded Knuckles and C-Cups or 4-link setup.
- Headlights and interior aren’t sealed, so moisture and debris get in easily. This can be easily fixed but why is it not made properly from the factory? It's a crawler + trail rig, not a carpet queen.
- Rear Red Light Diodes shine directly to your eyes when you control the Honcho from behind. Another lazy design fail for a trail rig. As my stock wiring has burnt anyway, I kept them disconnected. I may point them downwards or cover them for diffused light, that'll look nice.
- Foam inserts are too soft, and don’t support the tires well—aftermarket inserts are a must for a rig of this weight.
- SCX6 rolls over easily, even during light trail runs or sharp turns, due to poor center of gravity and flexing under throttle. It's the least capable stock rig I have ever had. Brass / aluminum upgrades are a must.
- Reverse is overpowered by default. I had to reprogram it to 50% to avoid harsh jerks while maneuvering—something that shouldn’t be necessary in a premium RTR. Get the LCD Spektrum Programmer V2 or replace the stock motor for Axe R3.
- My unit arrived with a manufacturing date from two years ago, which wasn’t a major issue, but it was surprising for a recent purchase.
- Stock wiring caused a fire. A pinch point between the rail and center mount. Apparently you have to check everything when you buy an Axial RTR. It's like buying a KIT that you have to disassemble first. See my other posts to learn about this issue in detail.
On the bright side:
- The stock servo works fine so far, which I know isn’t the case for everyone. I have added UBEC 10A and running it at 7.4V. But I don't do extreme crawling like many of you do. It's rated at 7.2V per Spektrum website, which can be a typo (unless they have tried to save $0.0001 when manufacturing it) so I thought it'll handle 7.4V.
- The stock motor is strong performer. I find it noisy but I'm in no rush to upgrade it. The speed is a bit underwhelming but it's OK for a crawler I guess. Running 3S and 4S.
- Body design (Honcho version) looks fantastic and has great visual presence. I love many design elements of the Honcho. I like the Jeep as well of course, both are great.
- Headlights are bright.
- Shocks perform well, no complaints there. Purple springs can be a nice upgrade for crawling.
- Wheels are good. I run them without the center covers, less screws = quicker maintenance.
- Tires are good, I like them. In no rush to upgrade. More than capable for my normal driving and steep crawling - you'll run to the limits of the lame R&D before you get to the limits of the tires.
- Transmission seems to be very durable. As I was forced to do the rebuild right away, I got to learn a lot about how the transmission works and it's well made in my opinion. Also the design of the clutch plates is good. You can totally use your SCX6 for towing, it'll handle pretty much everything - there are several impressive YouTube videos.
