Ok I'll try to remember everything I got done to her. Ok first off its 2wd I took the front diff axles and front dry shaft out so it's gets a little bit lighter and all the power to the rear end. I built the rear diff with 100k diff fluid, it has a 1258 savox throttle servo and a 1283 steering servo, 50 tooth RR spur and right now awaiting to send a picco 28 boost to ercm to be modded with a ercm side bleed pipe. For wheels it has badlands on traxxas geode wheels with blue rings, has rpm A arms, 4 little aluminum shocks up front 4 big bores in the rear, front and rear gh purple bulk heads, integy rear aluminum hubs that eliminate the turnbuckles, aluminum hpi front hubs and carriers, a aluminum rd logics fuel tank. I think that's everything. Hope you all like
