possibly my final update on this fuel tank project, and the truck project as whole,
if there are any more questions i will try to answer them as soon as i can,
I got to run the truck today and as the city has cut the grass in the woods/field next to my house i could open it up properly and test run time
first things first, i have decided to keep the tank mounted where it is with zip ties, it's not coming into contact with the exhaust manifold, i'm probably just going to make something on the fiberglass shell that will provide protection likely just two copper pipes bolted/riveted in place
I also made a mistake when i said i was changing to 52/14 i meant 49/14 ( did not need to adjust the 3 speed ) this was a major improvement with the bigger wheels, also its actually 25 leds and the digital voltage display
The engine ran very well today got a nice tune on it, no matter how hard i ran the engine it did not get very hot, i could actually rest my hand on the cooling head with no risk of burning it
i think my project is complete ( except getting a new engine when money allows )
nothing is in dire need of replacement,
pic of now flat fuel tank (no neck)
cut open and abused radio/battery box (1/5 sub C battery) yes it shows 3800MAH but its actually 4000MAH capacity was tested when cycling it for use with my charger (turnigy accucel 6 80W)
i know the shocks look overly preloaded, i have adjusted them properly now they were just like that while the grass was long to reduce drag
In this pic you can see fuel level when i stopped running the truck that was after 15 minutes give or take
