You'll need to turn the idle screw down some afterwards.
After the truck is fully warmed up with HSN set just lean enough to make the truck shift.
Then go after the LSN. Once it is set, you rarely need to move it, maybe 1-2 small turns once in a while. The HSN will require the most adjustment on a day to day basis, depending on what you are driving on, temps, humidity....
