Savage one way bearing?
simf40
RCTalk Racer
hi i'm cracked my one way bearing in my savage 25 and the bearing is a little bigger than the .21 engine because i have a spare .21 engine one way bearing but i'm not sure if it will work ok with it on there. or shall i get another stock one for the .254 engine.
Are you referring to the one way bearing for the roto-starter or pull starter? If so, I believe both .21 & .25s one way bearings are identical.
:wasted:
It is the same one way bearing in size for the 21 and 25 for pullstarter or roto starter. Same difference
good luck on getting some. I am repeairing my friends Savage 25 and his one way is shot and sidelines till the LHS AND HPI stock em. I have been told that the old Traxxas pro 15 will work. Not too sure on that. Just "heard" that. I feel for your pain buddy. Good luck!
Jon2 dude you are absolutely correct that the old trx 15 pro bearing will work. It is the exact same size as the savage one way bearing. I used it in a pinch. Problem is that it is not as durable at all. I would suggest just getting one from HPI. Hobbieguyrc usually has them on ebay no problem.
i used my spare 21bb one way bearing and it seems fine.
