savage 4.6 potential problume
thelocal17
I went out today and ran my savage, it is winter but it was running at 200 degrees and only for about 3 or 4 minutes. I brought it in and it bogged down a ton then shut off. Then I started it back up and when I pressed the throttle and it bogged right down. So I took it in and wiped the snow off it and steering and throttle servo still work but now it just wont start I am not sure whats wrong.
You may have got water in your carb from the snow. Id clean it with wd40. Then put a drop or 2 of after run oil in it. Then try. Check your glow plug as well.
