This is a list of whats on the truck.The engine has only had 1 and barely a half a tank ran through it. It also has the rotostart with it. Engine starts on 1 to 3 tries. Just needs to tune to your climate.
dual brake discs
light weight flywheel
aluminum clutch shoes(hardly used)
aluminum fuel tank mounts
2 carbon fiber brake discs( 1 is ok, other is a little worn)
hotbodies tunned black pipe
new style antenna
EXTRAS
stock a arms
1 diff box
brake pads
fuel tubing
stock pipe
2 glow plugs
few problems
radio is fine but the reciever only turns the steering half way
savage is missing like 6 screws( a screw kit should do the trick)
truck has miss match tires( these tires are brand new just miss matched)
All you need is a screw kit, 1 pair of tires, reciever
I will also throw in hpi's rechargeable glow igniter, more than half a gallon of gas,tire glue, and a battery stick for the rotostart.
Not sure how much to ask but makek offers
dual brake discs
new style antenna
EXTRAS
stock a arms
1 diff box
brake pads
fuel tubing
stock pipe
2 glow plugs
few problems
