sav 25 radio lid cover
cbaker76
How do i get this thing on without smashing my wires its a pain its the lid cover on the truck
First, route your wires so that they are a compact as possible and as much as you can get between the servos. Carefully bend the wires comming out of the reciever so that they are flat, and also as compact as possible. Make sure that the Rx deck sits flat on the servos and no wores are between the deck and the servos. Once you have all this in place, push the front suspension down so it bottoms out and put the lid on front end first, then seat the rear end and put the clips on.
Whitt...
like error said keep the wires as compact as possible, also a slick trick that works well is to take a dremmel tool and cut the fronts out of the two front holes and instead of having to fit them over the posts, you can slide the cover in then put the back of the cover over the back posts and put your pins back on. works really great
