Buggyracer28
Well, sounds crazy.... Heres my story. I am almost positive a little spec or 2 of dirt got in through my carb, which scratched a little of my con rod which came up through the sides of the piston (? microscopic) then getting stuck at the top of the piston and denting (extremely small) the top of the piston which IS THE REASON (finally) that is killing my glow plugs....
NOW, The piston and con rod are FINE. The top of the piston is just kinda ruff with minor indents on top. I tried just straight buffing it out with the dremel and it helped, but there are still some little bumps. If i sanded the top of the piston with maybe 600 grit sand paper, then buffed the top out evenly, will my piston life another day? The con rod is fine, just minor scratches (think ipod nano). If this does work, it will save me $79.99 + shipping. Worse case scenario I'm thinking i might need a pinch which is ALOT cheaper... If its worth trying, i have nothing to loose. If I didn't think it was salvageable I wouldnt ask. I can take pics if it helps.
