y r u trying to remove the sleeve? :hammer: take the head off, and take the pull start and back plate off, use a soft (no sharp!) object to push the sleeve up from the crankcase housing, then use pliers and a soft towel to pinch the sleeve and pull it up, be aware when you put it back in that there is a set key on the inside of the sleeve housing in the crankcase where the slot on the sleeve has to match up or else your timing will be off. if it wont budge, you can put your motor in the freezer for a bit to loosen it up some.
