s-25 flywheel removal
gta18
RCTalk Racer
hi, just wanted to ask on what is the easiest way to remove the s-25 flywheel? thanks
Ummm remove the clutch bell and clutch. Ok now that is done just loosen the clutch nut and it should remove no problems.
i always use a flathead screwdriver and place it in between the block case and the fly wheel, give the screwdriver a gentle turn and the flywheel always pops off. this is of course after clutch/bell/nut has been removed.
A cheap battery terminal puller at your local auto parts store works awesome for removing stubborn flywheels.
thanks guys! i just didn't want to mess up anything in my engine when forcing it out. thanks for the quick info! :):dance:
