Running Good??Qestionable
jarin12ga
I finally have my new 3.3 tmaxx running good.It wheelies sometimes, but not all the time??I think it has to be leaned out a little more.I just don't know how fast it should be?My nitro rustler is half the size,so of coarse it's going to take a little longer to pick up speed.It still rips! but I'm going to lean it out more and see what happends.Should it bang wheelies in a drop of a hat,or not?I have the BIG 6 inch V tires.It revs out good, but it doesn't have a fast low end snap like my 2.5 rustler.Should I mess with the low end idle?The idle seems fine from just the adjustments on the controller?
My t maxx would wheelie on demand so you may need to lean the hsn and lsn just a touch. Whats your temps where you have it now. If your temps are good and it's running really good you may need to check your slipper and make sure it isn't to loose. If it bogs a little on take off and your temps are around 200 you are just a little to rich if your temps are higher than 250 your too lean which will cause it to have a sluggish take off too.
Yea I have to get a rc temp tool now that own two cars.It don"t bog off the line,it just don't wheelie when I nail it!It just hooks up and goes. Sometimes it wheelies around mid range?I'm going to lean it out today after my kid and I nap.
Sounds like your Hsn is still too rich. Once you get the tunes right it will be super snappy off the line and wheelie easy.
