MRstar02
I have Savage X with the 4.6. I bought it used (less than a month ago) and when I used to try and start it it would only catch every once in a while. I read up on it and heard that the bearing could be the issue. Replaced the bearing it started with no problems. I went to go play with it yesterday I have put LESS than a quart of nitro through it. I went to go start it....nothing It wouldn't catch, it wouldn't start it, it wouldn't do anything it would just sit there and spin. So I took it all back apart and found out that the bearing was broken (almost in half) again!! Is that a common thing?! Do they go that bad that fast or did I just get a bum bearing from the factory? Is there something that I may have done wrong when I installed it? Would I be better off replace it with a pull start or are those just as bad? Thanks for the help
