Roll Cages
Raiden101
South Florida
I've looked around on the Internet ALOT and I can't find a roll cage for a slayer. I know you guys probably aren't the best to aske, this being a revo forum, but I figured you could at least give me somewhere else to look.
The closest thing I can find is a replacement for the plastic roll bar in the middle, but not a full one like I've found for many other trucks
Aren't the Slayer and Revo 2.5 chassis the same? I believe the 2.5 cage will fit but I may be wrong. If so there are a ton of options but I like the RC solutions cage myself.
The problem with the revo cage is that I don't think the slayer body will fit
According to Hard bodies, the 2.5 will fit the slayer.
I noticed Integarbage makes a cage that comes in pieces. Do they normally, or is that just integy
Yep. I had one. Great for protecting from a direct roof landing, but they would really tweak on you if you landed at an angle. They would protect, but they would bend and break as they did it. They worked a lot better when you ran a body. The cage would absorb the impact and the body would let it slide instead of the cage digging into the ground.
For a decent roll bar though, go look at new era's 3-point bars. Tough as nails and less likely to have an issue with body clearance:
http://www.neweramodels.com/item.cgi?session_id=&part_id=2291
I've seen ones like that, but I'm looking more for a full cage. I'm looking into the one Greg has, it seems like it will work, he just doesn't seem to be very active on RCNT, so communication is limited, but I'm not in a huge rush to get one
