That HPI pipe certainly isn't ribbed for the engine's pleasure. There's no cone and it's just straight through/wide open. I was thinking about this on my way home earlier.
Following 2 cycle engine theory:
Q:Why is it bad for a 2 stroke to have little or no back pressure?
A: Burnt piston. If there is little back pressure, there is nothing to really hold the 'fire' in the cylinder. Over time it can errode the clynder near the exhaust port and you will lose compression, scar the cylinder, scar the piston wall(s).. etc etc.
Also. When there is lower back pressure, you lose the torque, or the low end, off idle grunt. Wanted the ofna pipe, but I wanted something different for now.
Just picked up an HPI Tuned pipe. Going to take the truck out now.
-=EDIT=-
Gotta wait till tomorrow to re-tune it. Can't see the exhaust or the car and it's getting cold. Supposed to be nice tomorrow!
47*! It fired right up a couple minutes ago. Plugged the exhaust just long enough to push some fuel into the lines, sputtered, waited and fired up.
I gotta find a small piece of aluminum tomorrow to measure and cut to 1mm so I can measure the throttle spacing. Re geared it and installed new clutch shoe springs. Got a servo-saver kit, but I'll install that tomorrow or this weekend.
-=EDIT=-
