i just got done with some new parts on front chasis,and i sat it down and it wont roll,the front and back weelswill spin seperatly but all four wont roll together,please help
Did you remove the front diff? If so did you take it apart?
If you did there is a very good possibility that you put the front diff back in upside down. Now your front wheels are trying to go backward and the two ends are pushing against one another.
i think your drive shafts are probably binding on the a arms.. try checking it at different positions.. if that lets it roll right.. then your problem is the ball ends. you may have ran them in too far causing the bind. I am guessing this because you did the front end work and it started happening... good luck..
