Wow, I should have been on sooner!!
I own a revo plat so I can give my knowledge. Ok first off there both good sturdy trucks. The revo 3.3 is more of a basher while the revo platinum is a race "truggy"!! The revo platinum is the stock revo 3.3 but with all these upgrades/ what comes with it.
* Larger 150cc Revo fuel tank for superior sealing and consistent fuel delivery during long mains
* Sway bar kit with red-anodized front turnbuckles
* Hard-anodized, Teflon®-coated GTR shocks
* Smooth and durable TiN shock shafts
* Variable damper shock pistons
* 50WT shock oil, orange front & gold rear shock springs
* Tight-handling progressive-2 rockers
* Digital waterproof servos for steering and throttle deliver 125 oz-in & 0.16-sec transit times
* Titanium-anodized chassis and chassis brace
* Compact receiver and battery box
* Integrated personal transponder mount
* Includes rechargeable high-capacity NiMh receiver battery pack and on/off wiring harness
* Autoshifting two-speed is simple, reliable, & easy to adjust
o Two-speed forward only transmission
o Ultra-compact. Fewer moving parts
o Low rotating mass for quick, high-revving acceleration
o Autoshifting two-speed is simple, reliable, and easy to adjust
o Constant drive engagement is smooth and instantly responsive
o Sealed case protects gears & 2-speed from damaging track debris
* Forward-only transmission reduces rotating mass
* Close ratio two-speed gear set for smooth power delivery
* High-performance vented front disc brake
* Dual-disc rear brake kit with adjustable linkage
* Sealed center differential with 500K weight oil
* Compact throttle servo mount with air filter support
* Mirror-polish Resonator® dual-chamber tuned pipe
* Durable spring-mounted header allows pipe movement to prevent impact damage
* Ball bearing throttle bellcrank with lightweight return spring
* Black silicone exhaust coupler and deflector
* Machined aluminum 40mm flywheel for use w/ starter boxes
* High-revving
TRX 3.3 Racing Engine for proven championship-winning horsepower and speed
o Bigger piston and sleeve delivers extreme power
o Consistent and smooth throughout the entire power band
o Straight-through exhaust flow
o Slide carburetor
o Knife-edged connecting rod
o Large aluminum blue-anodized cooling head
o Super-light piston and rod
o High-performance ball bearings
o Backed by Traxxas Lifetime Engine Replacement Plan.
* New high-volume dual-stage air filter
* IPS crankshaft and backplate for maximized horsepower
* TUBES red-anodized 7075-T6 front and rear toe-links
* Red-anodized push rods with steel threaded inserts
* Extended wheelbase, adjustable rear suspension arms
* Formula-1 style high-downforce black Revo wing
* Wing mount offers adjustable height and deflection angle
* Response Pro tires with performance-tuned foam inserts
* 3.8" White dish wheel uses innovative 17mm splined hex that is also compatible with standard 17mm hex wheels
* Aluminum 17mm splined wheel hub and hex nut
* Includes 17mm molded wheel wrench
* New steering components allow maximum steering throw
* Large-bearing nylon axle housings with 13mm outer bearings
* Steel pivot ball retaining rings
* Compact black-chrome bumpers
* Blue-anodized antenna crimp nut
* Low-profile body posts
* 50k weight front and 10k weight rear differential oil
* Clear, trimmed fastback racing body
* Includes the following tuning options:
o Tuning shock springs
o 40WT and 60WT shock oil
o Thick sway bars
o 36-Tooth and 40-tooth spur gears
o 16-Tooth Clutch Bell
o Y-harness for dual steering servos
(from the traxxas website)
Sure it's a more expensive truck but to me it's worth it. It cost roughly 700.00 for the truck. If you don't have a radio thats around 40-60.00 for a traxxas one. It cost around 30.00 for a traxxas micro receiver. Bump box can be any weres from 0-140.00 depending on brand. 12v Gell cell and charger 30-40 total. The stuff and price of what I used was:
Revo Plat $700.00
TraxxasMicro Reciever $30.00
Paint $10.00
Traxxas Carbon Fiber wing $20.00
RD Logics Bump box $134.00
Gell cell 20.00
Charger for gell cell 15.00
Total= $819.00 w/o tax
If you don't want to drop this much cash the stock is fine!!! Hope this helped
