Revo tuning help please
revorapper
Hello i am tuningmy revo now i have it running about 260-270i was told this would be a good temp to run around well when i do that it seems to boog a little off the line but runs fine every where else where should i go from here ?
Check your LSN. Do the pinch test, with the engine warmed up at idle pinch the fuel line. The engine should run for about 4-5 seconds and shut off. If it runs longer your too rich, shorter and your too lean. Sounds like you might be on the rich side FMRE.
Ditto, what jetmech says....
270 is a little high if you are getting that temp without hard running. Do you see steam?
I called traxxas cause my engine ran around 270, they said highest timp it should be running at was 255.
