I am thinking I have stripped a gear in the transmission. I had a rock get stuck in my rear drive train and tore up one of my drive shafts really bad. Ground it down to the point that it would not move up and down with my suspension anymore.
After replacing the drive shaft now when I spin both rear wheels backwards and forwards I hit a crunch point where the transmission just stops and can move forward again with a little bit of grinding sounds. Front and Rear differentials all seem to be in good shape after eating this rock.
Since I am going to have to pull the transmission out and inspect it I want to install a forward only conversion while I rebuild it. Accidentally already purchased the parts when I was performing a forward only conversion on my T Maxx Transmission.
Now I am looking for the bearings and will not know what other parts are required till I tear it apart.
This post is just informational on an experiance I have had. No need for advice unless you want to provide me with all the part numbers I require to rebuild the Transmission
