I have a new Revo that I just finished breaking in. I am in the tune in portion and I can not seem to keep the motor temp below 300 at the glow plug. I think I have it running rich enough and as I rich the high-speed needle even more the temp does not seem to go down. I have cut the windows out for more ventilation and made sure to keep the air cleaner clean. It seems to idle well, maybe a little fast, at it does not stall on quick stops or breaking. The high-speed needle is about 4.5 turns out from full closed. The low speed needle is adjusted about a quarter turn from full close. I have not had to do much adjusting on idle speed. It may be a 1/8 to ¼ from factory setting. I may have my terminology wrong. I am calling the idle speed the adjustment screw facing away from the center of the truck (the larger adjusting screw) and I am calling the low speed adjustment the small adjusting screw located right below the high-speed adjustment screw and facing the center of the truck body.
As this is my first nitro, I may not be running it as it should be run. I read a post that said nitros are only meant to run at top speed for a few seconds. I am running this on a flat soccer field, wide open for at least 30 seconds plus them measuring temp. If I hot rod it around and only hit top speed for a couple of seconds and measure temp, it seems to measure around the 260-280 mark.
I am running 20% nitro, not sure of the brand, but it was recommend by the shop that sold the truck.
