revo keeps stalling
nicholas655
alright so i got it to shift , but the only problem is the stalling factor, i have a haard time keeping her going , it was about 34 out today so i dont think it was that , i had the hsn down right abit on the rich side , running 230 240 , i know you have all heard this one before at some time or another,oh ya and most if the time i have to pull the trigger to start it , like boost abit with gas is that normal ?
any ideas???
Tried a new glo plug by any chance. Pluse when my 2.5 keep stalling it was cause i was too lean on the lsn.
Bryson
glow plugs are fine it still burns when i test it , at the end when i tried the pinch test it lasted 4 - 5 secs , i have to retune tomorrow
nicolas,
Do not underestimate the impact outside temps will have on your running. I had the same problems as you, however, I kept my tune set to "rich". More than I needed too..Just to be safe. Now that temps are a bit higher, I may be a bit on the rich side but am getting good temps, and solid performance. As the temps rise I will adjust accordingly. I had some issues when trying to run in the 30's....I think that may be what is going on for you...Good Luck...
Hawk
ya i find if i run too rich it dies out but i will try again tomorrow and see if that works
