Revo Idle problem
REV0
Hey guys! I was at the track today, and had a problem with my revo. It was starting fine, until i stripped a spur. So, i went and bought a new spur along with a new engine mount. I installed the engine mount on my revo, and now my revo doesn't start normally. It was starting with one bump before i installed the engine mount, and now it doesn't start unless i give it some throttle. Also it can't idle for 60 secs, it just idles for about 5 seconds and dies. Any ideas how to fix this? Thanks. Someone told me that it was the clutch spring or something. I also never touched the HSN and LSN so it can't be tune.
The spur gear stripped because i had a broken engine mount. The engine mount loosened up when i did a jump causing the clutch bell to not mesh together with the spur gear.
But you may also have a clutch problem.
...And just because you haven't touched the needles doesn't mean the tune is good.
Thanks for your reply! Turns out it was the clutch spring.
