Take your air filter tube off and see if the carb is closing all the way when not off the throttle. Check the linkage to the servo and be sure that it has not come loose etc. Also when the filter is off run the idle screw in and out and see if it changes inside the carb at all. I had the same issue as you and the carb and linkage ended up being messed up. g/l
