revo 3.3 help
vjphotos
miami
I charged my stuff right, the truck and the ez start. i fill the gas and then i put the ez start in and then when i click it to turn on none of the 2 lights turn on and my car dosent make a sound at all just sits there looking. what do u think it could me wrong with it.
check the wires that go from the where you plug in the wand to the little electric motor thaty turns the engine over and make sure the engine is not flooded
It sounds to me like maybe the battery in your EZ start is dead, did you check it in another device to see if it's charged?
If you have a multi-meter check the + and - wires going to the EZ start motor. IT should be around 7.5V . Now set it to ohm and make sure the motor reads 0.0 .... If all that reads correct, take apart the Ez start gearing system and make sure everything is spinning inside freely.
If the battery IS charged properly then its a problem with the starter itself. The motor light lights up whether its plugged in or not. So if there are NO lights, then the problems the battery or starter.
