Remedy to savage understeer anyone??
Gofimoid
RCTalk Racer
hey guys i got my SS a few monthes ago and it drives great for the most part, i have had no problems bashing around the yard and stuff. But today i took it to the local track and i a noticed that once in the confines of the track barriers i am getting a lot of understeer. typicly i like to be able to slide into turns but it just isn't wanting to turn. i have a high torque steering servo so i don't think that could be causing the problem. it just feels like the front doesn't want to hook up. anyone know of a change in suspension setup or something to cure it? I once heard that if you pack the rear diff with heavy grease or do the mod to add an extra set of spider gears it helps a bit. but any input would be appreciated. thanks
here are the end results....
i never had a problem, just did this cause it was recommended for .26 users...
thanks guys ill try that out in a while and see how it does. so just to clarify i should but heavy oil in the rear and lighter oil in the front if i want over steer right?
This is the race set up I got from one of the team Houston guys. It has helped me alot & the mod will help with the under steer problem.
ride height
Front "arms" level
Rear "dogbones" level
-shocks (stock shocks are used)
Front 25wt oil with 3/4" internal limiter
Rear 25wt oil with 1/2" internal limitter
-camber (HPI adjustable links used)
Front 3 deg
Rear 3 deg
-toe
Front shorten rod to 43.5mm
Rear shorten rod to 43.5mm
-diffs (ofna diff oil)
Front 3,000 wt w/4 spider gears
Rear 1,000 wt w/spider gears
-tires
Pro-line Mashers (could be better depends on your track)
-inserts
Inserts Trinity T-max foam insert (firmest and most durable
insert out there, really helps with the steering)
-rims
Maximizer beadlocks, Aluminum (no stripped hexs)
-servo saver
Monster Pirate Servo Saver
-Radio Gear
Transmitter: Airtronics MX-3
steering: Airtronices 358 servo(200oz)
throttle: Stock sterring servo moved to throttle
battery: 1150 mah 5 cell pack
personnal transponder
ok thanks a bunch guys ill try that and see if it works out
