Rear Steering...
m00nst0ne69
RCTalk Champion
If I am using a three channel radio, can I use the third channel to turn off the signal to the rear steering in a dual steering set up?
I am thinking of setting up rear steering but rather then have it run full time, use the third channel of my radio to either cut power to the servo or to cut the signal to it. That way allowing me to use it on demand.
Found my manual and then did some reading. I didn't know it would do channel mixing.
I acutally have one of those from my REVO. But I like the XS3 better.
Awesome a few new Scorpion builds! I'm expecting my backordered AX10 from Tower in a couple weeks. I want to do the 4wsteering too, let us know how it goes m00n.
Will do but it won't be for a while...my scorpion and Rooster Crawler are being held hostage until Christmas Oh well that will give me time to get the motor, receiver, servos and batteries hehehehe!
I may be showing you how to do it by then <G>. Though the back-order is pushed back to early Oct.
I do have a couple questions for anybody that has one....
1) Does Axial offer a Rear-Steer "kit" part number? Or which length drag link, pitman arm, ball-studs, and does the 2nd servo plate come with the kit?
2) Can someone measure the distance of the body-mount stop -to- body mount stop? I'm getting the AX10 to build a Grave Digger. Parma makes 2 panel truck bodies 10th and 8th scale (I thought with the longer wb, the 8th might look right) 10th is 174mm wide, and 8th is 195mm wide.
Tires I plan to use
No there is no rear steering kit offered but the truck is set up to accept it readily. I mean there are no differences between the front axel and rear. It comes down to getting just a few extra parts.
