rear exost
tmaxx 3.3 boss
RCTalk Qualifier
I'm tiered of my truck being covered with dirt because of the exost spitting on the passenger side. is there a way to switch the stock pipe around without having to buy a new pipe. its a 3.3 stock pipe, i could use my old 2.5 pipe if i needed to
Only way to completely eliminate getting fuel on your Nitro Rc......Go to electric......LOL
Or, you can just push up and down the street with no eng on the chassis.
go to http://www.rdlogics.com/ they have a rear exhaust. they have quit a few, so read carfully, to get the right one. you do have to tinker to get it on. its louder than stock. and more power.
I'm with Matt, i had a set of rear duals on a Revo i had, And they sucked!!!! no tune, and no power at all!!Buy the Deflector and be done with it.
mine works fine. course i put a check valve in the line to hold pressure in the tank, with a small pressure release hole.
ok you can pretty much just put a piece of pipe on the tip. does it have to be rubber
i have seen a few guys used copper tubing and run it out the back of the truck, but i have never done that myself. rubber is nice if you hit something it just pops back into place. and it's light and easy !
Ok cause the little rubberish tip that comes on it melted along time ago
