- Central Florida
- Racing
I picked up one the new RC4WD fully functioning officially licensed High Lift Jacks.
Upon arrival the jack came in a nice clam shell package. It included a 1/10 High Lift jack and High Lift decal sheet.
I was surprised at the detail of the jack. The finish looked great, and the overall attention to detail was amazing.
It was strong enough to hold up my heavy Jeep tuber, and looked great mounted to the rear deck. I used this to replace the static Tamiya jack I had mounted there previously. No doubt I will be picking up a few more for my other scale projects. If you are looking for a great looking, fully functioning scale High Lift jack for your scale rc you won't be disappointed.
Jack Specifications: (From RC4WD)
- Red Paint Work
- Steel Standard Bar
- Top Clamp - Clevis
- Black Handle
- Handle Clip Spring
- Pitman
- Base Plate
- Total Height: 5.35in / 135.8mm
- Total Width: 1.45in / 36.8mm
- Base Plate Width: 1.1in / 28mm
- Base Plate Length: 0.63in / 16mm
- Handle Length: 2.95in / 75mm
- Handle OD: 0.16in / 3.95mm
- Steel Standard Bar Hole Width: 0.12in / 3mm
- Steel Standard Bar Hole Length: 0.08in / 2mm
- Steel Standard Bar Width: 0.28in / 7.2mm
- Weight: 1.59oz / 45g
