nitro_salsa
Newbie to cars/trucks - Had an airplane in the early 80's so I've been around the hobby a long time.
I've got a .15 mill running in my RC10. When I go to pull start it, it seems to have compression-a-plenty, but it doesn't start very quickly. Primarily due to the fact that after 3 or 4 pulls it's like no compression at all. I just replaced the zip-start on the engine, and this is when the problem started.
I'm inclined to believe that something in the new pull-start is off, or the nut with the bearings in it is bad/dammaged/messed up somehow.
Or do I have real problems?
This thing runs a stinger pipe (the only mod on it) and on short grass has so much torque it's hard to steer unless I lay on the brake, in fact it won't even turn while accelerating. Yes and I need some weight in the front end to help it stay on the ground. So I know I've got a mean machine, it's just getting it started.
After the engine starts once, it'll start again without any trouble at all (when it stalls) but the initial get-it-going when it's cold is about to torque me off.
Any suggestions???
Thanks
Jim
