radio interferance
bad73rs
Fremont CA
Has anyone out there using a roll cage had problems with the radio interferance for example i have a fail safe and about every 10 feet the fail safe comes on. All the batteries are good and the hump pack is charged help is greatly appreciated. Thanx.
I know this sounds like stupid stuff, but... is your Tx antenna all the way up? How bout your receiver antenna? It's not cut or been shortened right? I doubt the roll cage is the problem.. Lot's of people run roll cages. There's a signal issue somewhere. You've already got the power option covered with fresh batteries so it must be a matter of receiving the signal.
I would unhook the fail safe and see if it runs ok. Fail safe could be having issues, especially if it has gotten wet or muddy.
I checked every thing that you guys have suggested and i even went and bought a new futaba FM radion system and still no luck.
