MaxxFX, 4 weeks is NOT going to kill your fuel. If it does, it wouldn't be for any ofthe reasons mentioned here. You probably just have tuning issues due to changing weather. How full was the container? Read on . . .
aj200415 said:
First off, you should probably look up the MSDS sheet on nitromethane. It has a viscosity (i.e., evaporative rate) that is approximately equivalent to water.
Alcohol, on the other hand, which makes up from 50-75% of our nitro
fuel, has a very high viscosity rate. The point is - if anything is
evaporating it's going to be the alcohol. But that's not what makes fuel go BAD. It's the hygroscopic properties of the alcohol. Alcohol condenses water from the AIR. The water contaminates the fuel, not the evaporation. The evaporation of alcohol only accellerates the process, and evaporation is nearly impossible inside a sealed container - not
I'mpossible, but nearly.
aj200415 said:
i set my nitro in my garage, on the floor, and its very hot/humide in there. my fuel ran like crap about a week later. i threw it out.
I was schooled once on plastic containers by an ex-chemist: he made it very clear that the "non-porous" plastic containers our fuel come in are not actually non-porous but have a microscopic "webbing" of long plastic fibers. When you set fuel on a concrete floor, the dry and cold floor actually draws out the nitromethane from the container through the plastic. Hence the
possibility of "evaporation" in a sealed container. Never leave your fuel on a concrete floor, period.
If you've any doubt that it's the alcohol that's hygroscopic - go to your bathroom right now and without picking it up, look closely at the bottle of isopropyl alcohol you'll find there. See the droplets on the inside of the container? No nitromethane in isopropyl alcohol.
The best thing to preserve your fuel is to squeeze all the air out of the container. This reduces the amount of surface area exposed to air (which is why I asked FX how much fuel was in the container.) If you have a half-gallon and in a hot garage, it's **possible** the fuel went bad from water contamination, but I really don't think so, not in four weeks. But if it did - that would be WHY.
