I also have that same mill, and at first break in, it was a bitch to pull, I just got an os21rgx for my storm and there is no way I want to pull this bitch, It has the largest pull start asembly I have ever seen on a mill this size, and the compression is outrageuos! I also purchased a starter box and was told if I wanted to remove the pull start I would have to cut the shaft and get a backplate for it OR just take off the pull start body housing,remove the rope and spring coil put the housing back on and seal the hole where the rope was to keep out any dirt, this will allow the shaft to spin freely inside the pull body, doing this wont hurt or cost anything, you just have to look at a pull body on the mill,I will most likely do this after I get the starter box lined up. now, your os15cv-rx will start right up first or second pull once its broke in and tuned well, mine is a breeze to start now, and after pulling the 21rgx its extremely ez to pull! Good luck!
