Proline 3.8" badlands foam question?
pjoseph
RCTalk Qualifier
studio city CA
The foam that came with the badlands seems very big to me, do these need to be cut?
I was able to get the tire over them (tire on the far right) but before i glue them up i wanted to make sure. Also should the foam get glued to the rim? thanks
I didn't cut mine n never had a problem. Don't glue the foam just the tire.
I would not trim the foams, just Gorilla tape the inside of the tire, stuff the foams into the tires and glue the tires.
You can also balance you're tires with some cheap Walmart modeling clay and a homemade balancer.
I realize this was over a year ago but what did you use to take the place of the axle shaft?
