problems
TheDirtKing
RCTalk Rookie
Asheville
so I have a t maxx 2.5 put a new carburetor on a new fuel lines new spark plug and it'll start once and won't start again for about 20 minutes help me ......
just a quick question is the shut off pinched alittle? if not try richening it up i had the same thing happen with my 3.3 it wouldnt let fuel through when i leaned it i had to take it out like 4 turns then it ran great
When it starts r u able to run it around? Or does it start and die,then it dont start againg for 20 min? Little more info please...can't remember where but there is a tuning flowchart on this site..helped me with alot of my starting and dieing problems..
I can run it around once , then it dies in then it takes about 20 minutes to start again
t maxx 2.5 spur gear
i keep melting it and i do what the hoppy shop tell me to and i have melted 3 in one day and wanted to know if anyone has put a steel one. i also need to know on how to put it in and set it so i do not mass any more up
thanks byron
To the OP, how much fuel has been run through it?
A sign of a worn out engine is it starts & runs till it warms up then die's and will not restart till cold again.
i keep melting it and i do what the hobby shop tell me to and i have melted 3 in one day and wanted to know if anyone has put a steel one. i also need to know on how to put it in and set it so i do not mass any more up
thanks byron
Nice thread jack! You really need to start your own thread for your RC issues instead of posting your issue in someone else's. :)
You need to put new friction pegs in the spur use all 12, set the mesh correctly and tighten down the nut tight
& then back it off between 1/8~1/4 turn.
